Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
What opti are you running?
Old Apr 21, 2008 | 08:52 PM
jtarp's Avatar
Just like it says. I'm just wanting to see who is running what opti spark.
Old Apr 21, 2008 | 08:55 PM
Genuine GM / AC-Delco
You should have done a poll.
Old Apr 21, 2008 | 08:58 PM
jtarp's Avatar
yeah thought about it right after i posted this
Old Apr 21, 2008 | 10:29 PM
OEM AC/Delco (vented conversion), but I only need the optical sensor.
Old Apr 21, 2008 | 10:36 PM
Ricardo's Avatar
Genuine GM/AC Delco.
Disassembled once, found a rotor screw off, secured and loctited both screws.
Old Apr 21, 2008 | 10:37 PM
19z28camaro02's Avatar
OE OPTI, 87K miles
Old Apr 22, 2008 | 09:41 AM
2000GTP's Avatar
Original opti with 95K and a brand new Delco opti sitting in a box in the garage.
Old Apr 22, 2008 | 11:30 AM
9t4lt4z28's Avatar
Went with the Dynaspark.....seems like they have very good customer service. I called the guy and spoke to him on his personal cell...
Old Apr 23, 2008 | 12:43 PM
TRICK95's Avatar
Always used AC Delco. Would consider other option if there were enough reviews or any showing an improvement over stock dollar for dollar.
Old Apr 28, 2008 | 04:47 PM
sn8ke eatr's Avatar
oem delco. old one just started to go at 181k miles
Old Apr 30, 2008 | 08:39 AM
mzgp5x's Avatar
GM OEM Opti (Pin drive) with modification. Changed to (2) alum 1/8" rivets in the copper rotor contact. Altered the vent circuit for more air flow. I had 2 rotor failures with the addition of an MSD6A and 8202 coil. Plastic rivets would not hold the copper contact. B.
Old May 2, 2008 | 12:32 AM
Hot Rod SS's Avatar
After 4 failed OEM opti's, I decided to give the MSD billet opti a try.... It works.
Some speculate aftermarket ignition enhancers, such as coils and ignition control moduls (such as MSD 6AL) can contribute to premature opti failures. This might be what caused mine to fail. Supposedly the MSD billet opti is built to compensate for these things. I can say this for sure, it's sure as hell built way better than the OEM POS.
Old May 2, 2008 | 01:00 AM
ZZ's Avatar
ZZ
I went with the MSD after replacing three AC Delco optis on my 93 over the last 11 years. It's only been on for a year and a half though, so the jury is still out on it. It sure ain't cheap.
Old May 2, 2008 | 07:19 AM
After having an MSD 6A and Blaster coil on my car for almost 10 years, I would have to say this is definitely not true. My OEM POS works very well.
IMHO, the MSD opti seems an expensive piece for the failure rate it seems to have.
Old May 2, 2008 | 08:26 AM
2000GTP's Avatar
I agree, considering the number of complaints and QC issues the MSD has had so far, I still think it is too soon to brand it as the superior design of the bunch.
