where is the firewall???
Old Dec 18, 2002 | 12:40 PM
nothingeined's Avatar
okay im installing my amp right now but i cannot how to that huge power cable to my battery. where is my firewall so i can get to it? also how do i get to it from the inside? its a 2000 camaro.
please help. thanks
Old Dec 18, 2002 | 12:44 PM
LS1 RULZ's Avatar
From the Electronics Forum at LS1.com...
Under the hood on the passenger side you'll see the PCM. Its far back towards the windshield. You'll see a lot of wires going in to a couple of harnesses that plug into it. Theres 2 10mm bolts that hold it in. Remove the 2 7mm bolts holding the harnesses in and set the harnesses aside. Then remove the 2 10mm bolts holding the PCM secure. Now you can turn the PCM sideways so that the part where the wires went is now facing the passenger fender. The PCM will now lift right out with ease. You could leave the harnesses attached but it causes you to have to struggle to get the PCM out of its cubby hole. You'll now see a rubber grommet in the firewall. You can fish your wire thru here. Now inside the car, go to the passenger kickpanel, up behind the glovebox you'll find your wire. Its usually easier to remove the kick panel to find the wire. Anytime you add any wires to the battery, make sure you fuse them within 18 inches of the battery.
Old Dec 18, 2002 | 12:47 PM
thank you very much LS1 RULZ now to go and finish this installation
RobFlag
Aug 29, 2015 11:40 PM
gelbza
Jul 12, 2015 08:10 AM
Rod Bender
May 16, 2015 02:16 PM
BradZ28
Jun 8, 2003 01:17 PM
kevmor99
Mar 26, 2003 09:35 PM
