Removing A/C unit near firewall......
Old Jun 5, 2003 | 01:14 PM
BradZ28's Avatar
Can it be done? I have 2 cars with the A/C removed but still have the large black plastic box near trhe firewall with the what looks like a small radator inside? Anyone have any advice or can this even be removed?
Brad
Old Jun 5, 2003 | 01:38 PM
GREGG 97Z's Avatar
That radiator looking part should be the condensor coil for the A/C system. I'm finally getting around to yanking my a/c system this weekend, I'm curious if that coil can be removed easily also, havn't looked at it to closely. I'll find out this weekend.
Old Jun 5, 2003 | 01:46 PM
RdRacerZ28's Avatar
Same here Greg.Remove the ECU and the black box un bolts from the firewal. Looks liek you have to put the box back in though to give the heater core a home. We'll find out!
Old Jun 6, 2003 | 01:32 PM
BradZ28's Avatar
Anyone else have experience with this?
Old Jun 8, 2003 | 01:17 PM
94bird's Avatar
Yes, just finished removing mine a few minutes ago. I'm also removing the heater though, so the whole unit is gone now. I'll use a thin sheet of aluminum to block up the hole in the firewall.
It's a WHOLE lot easier when you pull your dash out. There are some 10mm bolts you have to undo underneath the hood (about 5 of them) and then you have to pull the whole unit out through the inside.
I don't think I'd do this unless you're removing your heater also though, since the heater core and blower motor are all housed in things connected to the "black box" you see under your hood.
I haven't weighed everything yet, but it appears I've removed 45 lbs. easy from the car by doing this (AC and heater removal).
timmy39120
May 8, 2015 11:41 AM
Fatdog2
Apr 27, 2015 10:32 PM
alphaauto
Feb 5, 2015 05:25 PM
alphaauto
Jan 23, 2015 07:42 AM
pologreen97z
Dec 2, 2014 10:42 AM
