Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
stock pump supports how much rwph?
Old Apr 11, 2008 | 07:57 PM
z28_theantirice's Avatar
Just wondering how far people typically push the stock pump safely ?
Old Apr 11, 2008 | 08:18 PM
mdacton's Avatar
340
Old Apr 15, 2008 | 09:58 PM
sweetassz's Avatar
Believe it or not: 500rwhp on my set up,also have fp gauge to keep an I on it.
Old Apr 26, 2008 | 09:21 AM
akafred's Avatar
i made 416 rear wheel stock
Old Apr 26, 2008 | 09:49 AM
Hot Rod SS's Avatar
Looks like results vary. I'm nearing 400rwhp n/a stock bottom end 350 and my fuel system is completely sucked dry above 4700rpms. I have 30lb injectors and their running at 90% duty cycle. My fuel pressure drops a pound or two up top. I currently have an inline fuel pump awaiting installation along with 42# injectors. But as you can see in my thread I recently made I'm having issues with just "bolting in" my inline pump.
Old Apr 26, 2008 | 02:01 PM
Adding an inline booster pump isn't the way to increase your fuel flow. That's usually used when you want to increase both flow and pressure. Why not just replace the stock pump with a 255 LPH pump?
Old Apr 27, 2008 | 08:13 PM
I am in the process of installing the RaceTronix kit... I just wanted to hear what other people were getting out of the stock pumps
Old Apr 29, 2008 | 09:58 PM
Hot Rod SS's Avatar
x2
I'm ditching the inline pump, returning it tomorrow, and looking at a racetronix kit for myself. I'm curious as well...
Old Apr 30, 2008 | 12:34 PM
slomarao's Avatar
what is the stock pump rated at?
Old Jun 27, 2008 | 11:45 AM
CGrant's Avatar
I maxed mine out at 360rwhp during the dyno tune and it started to run lean after ~5500 rpm so i had no choice but to swap it out, i would just do it and be safe. I personally dont think its worth the risk!
Old Jun 27, 2008 | 04:23 PM
akafred's Avatar
at 330 hp your stock pump should be fine.. i made 416hp with my last engine on the stock pump.
now if you have a dying pump then it may become a problem.
Old Jul 8, 2008 | 09:59 PM
c5formula's Avatar
made 415rwhp on my stock pump with 37# injectors but started to run real lean after about 5000 rpms
Old Aug 22, 2008 | 11:22 PM
user 647483's Avatar
I'm not going to make quite that much power, but I'm concerned that my stock
pump may not handle the H/C 383 N/A. (If I ever do N20, I'll definitely have to upgrade)
I'm thinking it might be good insurance since I will be revving it to make use of this cam.
Old Aug 23, 2008 | 09:46 AM
akafred's Avatar
my pump on the new turbo setup was running out of steam at 4000 rpm... i am now doing tiwn walbors.. if your worried about your pump you can get a walbor 255lph pump for 99$ on ebay...
Old Sep 3, 2008 | 08:46 PM
wrd1972's Avatar
I am at 412 RWHP and cant detect any ill effects from my stock fuel pump. Pulls hard to 6.5K RPM wih 30# injectors.
HectorM52
Jul 30, 2017 11:46 AM
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
chevysam
Jan 16, 2015 07:45 PM
