to pass E-CHECK (ohio)
Old Apr 9, 2008 | 03:53 PM
Bluovlh8er's Avatar
hey i have to take the ride to get in e-checked soon. i gutted the cat. but the case is still there... its the test where they stick the thing up your tail pipe lol... so is this thing gunna fail? also i heard if you run a 1/4 tank and put some alcohol in the gas it helps... any tricks on this???
Old Apr 9, 2008 | 04:23 PM
ss.slp.ls1's Avatar
If you have to pass emissions, you won't pass without a cat. Leaning out your fuel (additive or calibration) will reduce your emissions, not sure by how much as I have never done it before.
Old Apr 10, 2008 | 11:02 AM
RE AND CHERYL's Avatar
Gutting the cat is worthless and in most casses gaines you no power due to the increased turbulance in the empty cat. You will also not pass an emissions test without it.
Re'
Old Apr 10, 2008 | 11:19 AM
2000GTP's Avatar
Gutting or removing the cat makes your chances of passing very slim to none. As mentioned above, there is very little, if anything, to be gained by gutting the cat. I would have a new one installed and let it be this time around.
Old Apr 10, 2008 | 01:37 PM
Bluovlh8er's Avatar
i do all my own work. i didnt want to spend the $ for the new cat. gutting it worked. like you all have stated... IT DID NO H/P increase lol. and acctually i dont even like the sound
Old Apr 11, 2008 | 01:55 PM
lt1loudmouth07
Guest
Posts: n/a
ECheck
Why do u have to get a E-check they did away with that in ohio. i am from there if they had echeck i would never be on the street lol
Old Apr 15, 2008 | 11:10 AM
01Z's Avatar
01Z
The thing they stick in your tailpipe will never reach your converter. The probe would have to be 12 feet long and able to negotiate the matrix within the muffler if you have one. Some cars can pass without a functional converter but they are close to failing. An astute worker will know you have altered the converter by the sound and odor.
They haven't done away with e-check. They have suspended the cost for the time being. Most counties do not have emission testing. Perhaps you live in one of those places or have moved to one.
Old Apr 15, 2008 | 04:57 PM
Fuel Fire Desire's Avatar
Although the OE cat is like $650 (I know, I had one replaced under warranty ) an aftermarket one is alot cheaper. I think I could have got a whole y-pipe/ high flow cat assembly from magnaflow for $250. A stand alone weld-in cat can be had for even less.
Old Apr 15, 2008 | 06:11 PM
Green96Z's Avatar
It doesn't need to reach the cat. With it gutted, the exhaust gasses are not cleaned up by the cat, so they exit the tailpipe. The sniffer picks up the CO and CO2 levels and then you fail.
With a gutted cat, you will most likely fail. Just have a shop weld in an aftermarket cat. They are fairly inexpensive.
Old Apr 24, 2008 | 12:47 PM
dre2013's Avatar
youll fail with a gutted cat. i have emissions in my county, but i register my cars(that wont pass lol) to stark county where they dont have echeck testing. i just told the people at the bmv that i go to school from the address, no questions asked. just make sure you memorize the address incase you get pulled over. i have been doing this for 3 yrs now and havent had a problem.
Old Apr 24, 2008 | 05:29 PM
Counted Out's Avatar
The alcohol stuff should work fine. My friend recently sold a 89 GTA to my neighbor because it wouldn't pass emissions. He put some of that "Guarantee to Pass" stuff in his gas, and well, he passed.
2QUIK6
Sep 17, 2016 02:31 PM
David Dempsey
Mar 12, 2016 12:42 AM
Daluchman1974
Sep 11, 2015 06:12 AM
heus
Sep 8, 2015 12:01 PM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
