shift light
Old Dec 18, 2002 | 12:55 AM
Barry's Avatar
shift light
I did some searches and found some of the stuff i was looking for but basically i am hooking up my autometer shift light and dont know exactly which wire to splice into for the signal. Does anyone happen to have a pic or a good description of which wire i am looking for? its on a 98 ls1.
Thanx!
Barry
Old Dec 18, 2002 | 09:00 PM
code4's Avatar
there are two 80 pin connectors on your pcm. one is red and the other blue. unplug them but be SURE you put them back the way they were, (red where the red was and blue where it was) the output pin is pin #35 on the blue connector. it should be a white wire coming out the back of #35 of the blue connector, you need to splice into this wire (it is your tach output wire)
Old Dec 19, 2002 | 04:32 AM
SSactionLs1's Avatar
dont forget to cut the wires for a 4cylinder(weird ls1 ignition)
Old Dec 22, 2002 | 11:21 AM
danner's Avatar
you can find the white tach wire on the lt side just below the fuel rails. You first have to open up the plastic protective outer tube cover that is leading to your coil and locate the white wire inside. I used one a crush type connector that neatly connects to wires togeather. I have been using a profrom shift light with no problems and is right on the nose with my factory tach.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
phantasm99
Aug 28, 2002 11:01 PM
Brady
Jul 29, 2002 10:30 PM
