HELP!! Can't figure it out. Thanks.
Old Mar 21, 2008 | 03:01 PM
mitchleftwich's Avatar
My LS1 car has 75000 miles. I did a turnup a couple months ago and everthing is fine. (all plugs, filters, etc.). I normally drive the car easy, but I had to show up a sportscar the other day and as I was accelerating hard the engine started to stutter bad like it was running out of gas. It would let me rev it up and then almost die or sometimes die. I was able to limp it home, but she barely ran.
Got home and checked the fuel pressure at the rail and it was 50 to 60 lbs and did not drop off while running except when it was about to die it went down a little. So I am getting plenty of gas, now what else could it be. Motor sounds fine when I rev it up, it just wont stay there and it wants to die. At idle its around 3 rpm and then dies.
is there a know issue that I'm overlooking? Called the dealer and he said it sounded like the distributor, but to me it runs like a fuel problem.
Thanks.
Old Mar 21, 2008 | 05:31 PM
Me>you's Avatar
Yeah, you definitely might want to get a new distributor...Could also possibly be a blockage in the carburetor...
Old Mar 21, 2008 | 05:34 PM
Me>you's Avatar
Try cleaning the MAF
dangalla's Avatar
i dont know much about the godly ls1, but i do know you got played by that dealer, like he hung up the phone and prolly fell on the floor laughing
you do not have a distributor, you have 8 individual coils, one for every plug, it could be a clogged fuel filter did you change that in your tune up
Old Mar 21, 2008 | 07:04 PM
Z28luvr's Avatar
Old Mar 21, 2008 | 09:25 PM
fuel filter?
I did change the fuel filter out a couple months ago and like I said the fuel pressure is 50 to 60 pounds. Would i get that with a plugged filter?
Thanks.
Old Mar 22, 2008 | 06:29 AM
Marc 85Z28's Avatar
It's either a fuel issue or a clogged catalytic converter.
You can test for a bad converter by removing both air injection lines at the exhaust manifolds and driving it. If it drives better and doesn't hit that 3000RPM wall, you have found your problem.
Old Mar 22, 2008 | 07:24 AM
Z28luvr's Avatar
^wouldn't that cause a serious exhaust leak?
Old Mar 22, 2008 | 07:52 AM
AL SS590 M6's Avatar
Moderator
That's the whole idea of doing it is to let the exhaust leak and not have to go thru the cats. If the cats are plugged letting the exhaist leak will allow the motor to run better.
Old Mar 23, 2008 | 01:05 AM
I figured it out
The guy that said check the mass air flow had it. I pulled the slp lid and found out the strip of foam tape that seal it had come loose and had went into the mass air flow sensor. I simply pulled it out, reglued it and reinstall. The car runs great now.
Thanks for your help guys.
Old Mar 23, 2008 | 05:15 AM
Me>you's Avatar
That'll be 85$ please
Victor Lamb
Aug 26, 2017 02:52 PM
beltrunner
May 17, 2015 10:18 PM
Biggiebound
Apr 21, 2015 11:28 PM
smokin25th
Jan 1, 2015 09:06 AM
Snake Slayer
Jul 29, 2002 12:39 PM
