How wide of a tire can go on the stock 16x8 wheel?
Old Mar 12, 2008 | 11:24 PM
Jazsun's Avatar
Currently I have 245, how big can you go?
Old Mar 13, 2008 | 11:11 AM
CheshireCat's Avatar
That depends on the tire profile among other things, but in a close to stock profile... 255
They aren't as common, so your selection will be limited. You're better off just finding a 245 that gets better traction. Unless you're doing it for looks, in which case, I don't think I could tell the 1cm difference from 30 feet away...
Old Mar 13, 2008 | 12:32 PM
Bud M's Avatar
As you go wider the tread gets less flat. If you're after the best performance, stick with the recommended tire size.
Old Mar 13, 2008 | 12:55 PM
As noted above, not a lot of choices, but how wide you can go depends on:
-type of tire you need (street, road race, drag, all-purpose, etc.)
-diameter of tire you need (limit to stock diameter, or go larger for drag tires)
BFG, for example makes 16" tires in their Radial T/A line (all season radial) up to 295 section width that will mount on an 8" wide wheel. But they are in diameters ranging from 26.5" - 30.1" (versus a stock diameter of 25.7" or 26.1").
265/60-16 - 26.5"
275/65-16 - 30.1"
285/60-16 - 29.5"
295/50-16 - 27.6"
I'll move this to the Wheels and Tires forum.
Old Mar 13, 2008 | 08:31 PM
BLK96Z28's Avatar
Im running 265/45-16's on my stock salad shooters.
Old Mar 13, 2008 | 10:29 PM
mrmint69's Avatar
I assume you looking for the widest tire that will still allow the car to handle safely. Going much bigger will just distort the tire and the contact on the road.
Old Mar 13, 2008 | 11:17 PM
Jazsun's Avatar
I'm asking because I saw a guy who has a WS6 Formula LT1 and it has some big *** tires on it, they werent drag radials I dont think. They looked to be around 285 or so. Is that possible on a WS6 wheel?
Old Mar 14, 2008 | 08:58 AM
If I'm not mistaken, the WS6 wheels weren't 16x8...
Old Mar 14, 2008 | 09:14 AM
JakeRobb's Avatar
Super Moderator
Yep, AFAIK they were 17x9, and came with 275/40 tires.
285 is about as big as you can go on a 17x9 before you start running into the same distortion issues as going bigger than 255 on a 16x8, unless you start increasing tire diameter.
Old Mar 14, 2008 | 09:52 AM
What brand? I've seen the Kumho V700 and V710 road race tires, but nothing in a street tire.
Old Mar 14, 2008 | 11:40 AM
BLK96Z28's Avatar
Kumho Ecsta V700. Not a street tire, but streetable. My car's not a daily driver though.
Old Mar 14, 2008 | 02:53 PM
mrmint69's Avatar
The widest tire wheel combo i have found is 17x11 with 315's and they need a little modification to fit. The 285's on the 17x9.5 is another size i see a lot.
Old Apr 3, 2008 | 11:49 AM
bthompson's Avatar
Both my brother and i run 245 on front and 255 Falken Ziex ZE 512's on back.
dpw21562
Jan 23, 2015 04:58 PM
Jason Short
Jan 19, 2015 06:33 PM
hotrodyou1
Dec 20, 2014 10:05 PM
globalprojeff
Dec 6, 2014 04:18 PM
globalprojeff
Wheels and Tires
Dec 6, 2014 04:09 PM
