98 Z-28 questions bout mods.
Old Mar 5, 2008 | 11:05 PM
mrpittbull's Avatar
I spun 2 rod bearings due to oil pump; I'm going to put a cam in and maybe headers, but I'm a little confused. It is my DD. I honestly just want a good sound from it. Im not gonna drag it or nothing. So what cam would give me that? And would I have to tune it? Everything is stock, trans,clutch, and rearend. Thanks for any info!
Old Mar 5, 2008 | 11:22 PM
Kraest's Avatar
Retired
You want a cam for the sound? Maybe headers?
Wow. Just wow.
Lemme give you the short of it -- if you do a cam, headers are a must. An aftermarket clutch is a must. Tuning IMO is a must for driveability. An aftermarket gear with a cam-swap is recommended.
Do a search. There are plenty of buildup questions on here.
Old Mar 10, 2008 | 02:13 AM
mrpittbull's Avatar
Thanks Kraest. I believe im goin with a MS3 and i'm lookin for a good set of headers right now. I also found a local shop to tune it after my mods. Hopefully it will all work out. I'll be posting again after im done.
Old Mar 10, 2008 | 07:56 AM
teke184's Avatar
"It is my DD... Im not gonna drag it or nothing"
and you've decided on the MS3??
another victim of bigcamitis....if not treated quickly it can easily become unhappywithmycamitis
go smaller, tight lobe separation for the sound you want...and get a good tune.
Old Mar 11, 2008 | 04:22 AM
mrpittbull's Avatar
More bad news....
Well, the motor is out and apart and ive found out I am going to have to rebuild it all the way through. The cylinder walls were scored pretty bad. This is getting ugly. I might as well stroke the damn thing. So, who makes a good stroker kit? Help would be appreciated!
Old Mar 11, 2008 | 07:47 AM
teke184's Avatar
by now all the major companies make them.
contact a sponsor
for a stroker...go custom cam. lots of lift, flycut and get compression up, and good heads....you'll have a monster!!
Old Mar 11, 2008 | 09:27 PM
mrpittbull's Avatar
New block...
I found a very good block with ls2 heads (with a new valve job) and new cam bearings in the block for 800.00. Now, are the LS2 heads better than my stock LS1 heads? I dont have a clue. Once again, all help would be appreciated!
Old Mar 12, 2008 | 09:27 AM
Kraest's Avatar
Retired
They make a little more power stock vs. stock. LS2 heads are really 243 casting LS6 heads.
Old Mar 13, 2008 | 09:43 PM
mrpittbull's Avatar
Heads...
Thanks again. I ordered my cam and all the pieces to go along with it. And also the LS6 oil pump. Anybody need a set of stock LS1 heads?!
Old Mar 23, 2008 | 10:42 PM
mrpittbull's Avatar
Clutch recomendations?
I am going to order a new clutch in the next couple of days, and was wondering what to order..010 over block, LS2 heads, MS3 cam and headers.
Old Mar 23, 2008 | 11:32 PM
Me>you's Avatar
spec stage 3...and get yourself an LS6 intake...
and i hope you really didn't buy an MS3...Unless you have a great tuner around, be prepared to hate that cam...YOu got springs and pushrods, and all that stuff too, right???
Old Mar 24, 2008 | 02:23 AM
mrpittbull's Avatar
Clutch
That was one I was looking at. Im sending TSP my computer and they are gonna tune it. Thanks.
Old Mar 24, 2008 | 02:27 AM
mrpittbull's Avatar
Clutch
That was one I was looking at. Im sending TSP my computer and they are gonna tune it. I got the cam install kit too.(pushrods,springs,retainers,lifters) Thanks.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
RUENUF
Mar 13, 2016 03:39 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
dawg irocz
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:33 AM
