Speedo inop.
Old Mar 4, 2008 | 08:39 PM
moroso99's Avatar
Speedo inop.
kinda wierd thing happened, the speedo works intermittingly. noticed it yesterday on a drive. all the other gauges work fine i was cruisin around 55 (i guess) and the speedo was on 0. then this morning it was working. this afternoon it wasnt...
anyone know why this would happen, could it just be wearing out?
Old Mar 5, 2008 | 08:34 AM
Speedo is driven by the VSS sensor on the tailshaft of the tranny housing, via the PCM. Do you have an SES light or a code for a VSS fault?
Old Mar 5, 2008 | 09:03 AM
Craddock's Avatar
If it was all the guages I'd say it was the alternator about to die, make sure it's just the speedo, cause when my guages started to do that it died in the next couple of days.
Old Mar 5, 2008 | 11:30 AM
moroso99's Avatar
theres no light or speed sensor code. not the alt., all my gauges died before but from a blown fuse. all the gauges work fine, just the speedo working, then not workin at all. its worked so far today, we'll see bout this afternoon...
Old Mar 5, 2008 | 01:10 PM
Does the odometer stop when the speedo stops?
Old Mar 5, 2008 | 03:41 PM
moroso99's Avatar
no. everything works fine, just the speedo doesnt work sometimes. started monday. is there somekind of motor or gears in the cluster operating the speedo that could be wearing out? cars almost 10 yrs old
Old Mar 5, 2008 | 04:39 PM
If the odometer keeps racking up miles, when the speedo is pointing to "0", the fault has to be in the panel. The PCM is sending the same signal to the speedo/odo, so the panel has to be getting the signal, if the odometer is ticking over. Swap in a panel from a junk yard. You can have a dealer adjust the miles on the odometer.
Sep 27, 2015 01:55 PM
mmf_1013
Sep 12, 2015 08:56 PM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
LazyLemming
Aug 29, 2015 07:36 PM
4586
Aug 24, 2015 11:04 PM
