where did u put your slp fan switch...?
Old Dec 15, 2002 | 03:11 AM
stik6shift98's Avatar
where inside did u mount it.....
pics would be a +
Old Dec 15, 2002 | 06:39 AM
MEAN LT1's Avatar
Sorry, no pics but it wasnt a big deal. I mounted mine right below my cigerette light. You cant even se it unless you look at it dead on .
Old Dec 15, 2002 | 09:04 AM
rwb's Avatar
rwb
I put mine in the ash tray. Easy to do, and cheap to replace if you ever have to remove it.
Old Dec 15, 2002 | 09:28 AM
amood's Avatar
I mounted mine through the face of the instrument bezel right under the temp. gauge. It turned out to be a little too inconspicuous though; I caused myself battery problems about 3 times before I started to get into the habit of making sure it was turned off!!!
Old Dec 15, 2002 | 12:44 PM
ratio411's Avatar
Exclamation Save about $80 on stat and switch!
Get a thermostatic fan switch.
It's alot cheaper (around $20), it doesn't require running wires in the cabin of the car, and it is fully automatic so it does the work and you never have to remember to flip the switch on or off.
I highly recommend it.
I have the free thermostat and the auto fan switch, my car runs a constant 175*. Very happy with the set-up.
Good luck
Dave
http://ls1info.com/article.php?sid=222
http://ls1info.com/article.php?sid=180
Old Dec 15, 2002 | 02:20 PM
ashtray.....cant i have my nx swithches there
i might put it by cigerette lighter
and i cant get a thermostatic because i already got this one
thanks a lot
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HCz28
Feb 15, 2015 03:01 PM
Rich_z28
Aug 29, 2002 11:01 PM
Rich_z28
Aug 29, 2002 10:44 PM
Rich_z28
Aug 27, 2002 12:20 AM
