Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
EVAP delete questions
Old Feb 23, 2008 | 02:06 PM
roadtrip120's Avatar
I pulled the EVAP canister off the car today.
What do i need to do with the line coming off the tank too the EVAP canister? Does it need to be capped off, if so.. Does the fuel tank need to be vented??
What do i need to do with the sensor at the motor that the EVAP line goes into on the passenger side?? Can i delete it all together?
Old Feb 24, 2008 | 08:34 PM
Fuel tank must be vented, the cap is "unvented". When I removed the canister, I left the hose in place in the rear fender, and put a piece of fabric over the end, to keep anything fromn crawling in it, but to allow air to flow in or out.... in effect, a coarse filter. You may notice a strong fuel smell at the rear of the car.
Its not a "sensor". Its the EVAP purge solenoid. You can remove it, but you will get a code for the electrical circuit not being complete. When you pull off the solenoid, measure the resistance, and put a similar value resistor in the end of the solenoid harness connector. Or have the code "programmed out" of your PCM.
Old Feb 25, 2008 | 07:29 PM
Thanks for the reply
Brady
Noenav
Mar 1, 2019 07:38 AM
IgorT.455/406
Mar 12, 2015 03:39 AM
alex5366
Mar 8, 2015 11:32 AM
alex5366
Feb 17, 2015 10:43 PM
cmdeshon
Dec 27, 2014 10:06 AM
