tps sensor
Old Feb 22, 2008 | 12:57 PM
97silvermaro's Avatar
tps sensor
http://www.golenengineservice.com/html/tps.html
would this mod make the o2's see a leaner mixture and richen it? how would this effect vacuum also?
Old Feb 22, 2008 | 01:54 PM
blkchevyz's Avatar
you shouldnt be opening it enough to really effect anything. i would just open enough to let the iac count within reason, it can handle the rest.
Old Feb 22, 2008 | 04:34 PM
It is only for use when you change to a throttle body that needs the throttle blades more open at closed throttle and puts the normal closed TPS reading out of range. It is not a mod anyone else needs to do.
FredM
Aug 14, 2015 01:49 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
