tc needs warming up!?
Old Jan 19, 2008 | 11:44 AM
LSWHO's Avatar
When I start my car when it is kinda cold out, the converter doesn't seem to engage. It'll get up to 4k and I still am not going anywhere. (3k stall) My drive is so short the car never gets to warm up! So it stays like this a lot. (my drive to work is less than a mile.)
Old Jan 19, 2008 | 12:43 PM
AutoRoc's Avatar
check fluid level
Old Jan 19, 2008 | 01:20 PM
Performabuilt's Avatar
Supporting Vendor
Yes check your fluid leve if anything with colder fluid your stall should be slighlty tigher, However do bear in mind the converter clutch will not lock up till the engine reachs around 130 degrees.
Old Jan 19, 2008 | 05:21 PM
LSWHO's Avatar
If anything I OVER filled the fluid. It sprayed out of the dipstick the other day. Any thoughts on THIS?
Old Jan 21, 2008 | 09:31 PM
LSWHO's Avatar
So since the fluid level is good, what else do I check????
David Dempsey
Mar 12, 2016 12:42 AM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
greenzee28
Sep 25, 2015 04:29 PM
tdigger9899
Sep 7, 2015 10:56 AM
