transmssion problem????????
Old Jan 9, 2008 | 05:16 PM
95camarodude's Avatar
Ok first off i was just driving and it did this. i was going to the gas station and i felt like a "clunk" (not to loud but not to quite) and next thing you know i can't shift into any gear. i finally got it to shift and drive far enough to pull into the gas station (about 100 ft coasted most of the way) but after that it wouldnt move in any gear. it will run but acts as if the clutch is engaged and wants to kill itself. softly it doesnt like jurk the car forward or nothin just idles for a couple of seceonds and kills itself. Motor is a fresh rebuild. and motor sounds fine when in neautral with the clutch engaged. it has to be something n the tranny or clutch assembly somewhere. Just replaced clutch with spec stage two+ and ran fine fr a while. this came out of nowhere. Any input, suggestions, or ideas would be great. thanks guys.
Old Jan 9, 2008 | 07:47 PM
nobody has any ideas at all. come on i need an idea of what it could be. this hasnthappened to anyone before?
Old Jan 9, 2008 | 07:56 PM
greenmachinedriver's Avatar
if i am reading this right your symptoms are that it is hard to get in gear and id dieas at idle when in gear. sounds like the clutch is not disengaging check the hydraulics. also the check the fork ti may have come off its pivot.
this probably does not belong in the lt section the drivetrain section would probably be more appropriate
Old Jan 9, 2008 | 07:58 PM
Javier97Z28's Avatar
Moderator
I'll move this to the drivetrain forum where our transmission sponsors can more properly assist you..
Old Jan 10, 2008 | 05:27 AM
'94 Bad A Z28's Avatar
Your description of what it is doing is kind of vague. But to me it sounds like a broken ring and pinion.
Old Jan 12, 2008 | 09:02 PM
it made a quite thunk and i had no gears. as in i couldnt shift into a gear. i finally got in 2nd but i had to shove it into gear. i pulled into the gas station and it felt like something in transmisson was binding. as in it would rotate but it felt like something was in the was. i put in reverse and it locked up the wheels so then i put it in neutral and pushed it into the parking spot. I really need some help with this situation, thanks for the so far also guys. you guys are awsome.
Old Jan 13, 2008 | 05:39 AM
Well you got me on that one then. I couldn't even tell you where to begin with that.
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
