pcv
Old Jan 5, 2008 | 11:23 PM
gilg99ss's Avatar
pcv
Would a bad pcv or pcv leak cause oil to leak out of the front of the valley cover on a LS1, or is it just in need of a new valley cover gasket?
Old Jan 6, 2008 | 08:57 AM
AL SS590 M6's Avatar
Moderator
Are you sure that's where it's coming from?? Never heard of one leaking before. As far as a PCV system problem causing it to leak it's doubtful.
PCV system problems on LS1s generally cause high oil consumption and oil in the intake manifold.
Old Jan 6, 2008 | 11:01 AM
RevXtreme1's Avatar
The most common source of a leak on a LS motor is the front seal....check it out closely to better determine the source.
Old Jan 6, 2008 | 11:10 AM
gilg99ss's Avatar
I have checked the front seal and its ok. There is a trail of oil leaking from the valley that just under the T.B. that leaks down to the front passenger corner of the oil pan and then trails all the way to the trans. I checked it with the car runnung and I see oil bubbling from the valley cover. I was wondering if there is too much pressure blowing it out from a bad pvc, or just a bad valley gasket.
Old Jan 6, 2008 | 03:39 PM
moroso99's Avatar
u could use a dye and a black light to find exactly where its coming from
Old Jan 6, 2008 | 08:38 PM
moroso99's Avatar
what type of oil are u using?, if the viscosity of the oil is to high or to low that culd cause problems too but that goes with ur cliamate, air temp.
Old Jan 6, 2008 | 10:15 PM
gilg99ss's Avatar
I use 5w-30 mobil 1 syn. 50 degrees today , it doesn't get too cold. I am going to attempt to remove the intake myself and change the valley gasket.
Old Jan 7, 2008 | 07:26 AM
Moderator
Yeah if you can actually see the oil bubbling out from under the cover then it needs a new gasket.
drt
Sep 27, 2015 04:39 PM
surreybrad
Aug 10, 2015 09:34 AM
mineralwater
Oct 17, 2003 05:34 PM
asianice25
Apr 2, 2003 11:42 AM
got_hp?
Mar 15, 2003 11:11 PM
