wanting to change from obd1 to obd2
Old Dec 22, 2007 | 09:06 AM
93camarochrisz28's Avatar
Question wanting to change from obd1 to obd2
is there any wire ups and parts list that i can get.i have no clue how to change it but i want to so any help would be cool thanks
oh and i have the car in my sig (93) and i want to get like a 94 pcm for it so i can get a dyno tune and not have to order a chip for it am i able to change that to and how hard is that to do
Old Dec 22, 2007 | 09:31 AM
chasmosis1's Avatar
You may want to do a little research before people start flaming you. 94 was still OBDI. OBDII was not used until 96, so you are just trying to use a different OBDI setup as an OBDII conversion would be alot of work and not worth it. Converting to OBDII requires changing the timing cover and installing a third O2 sensor.
That being said, I'm not sure what it would take to convert from 93 to 94-95 OBDI, but at least now you can ask the correct question.
Old Dec 22, 2007 | 09:45 AM
i thought that 95 was that frist year for obd2 but besides that when i said like a 94 i meant one that was able to get dyno tuned and not have a chip burned for it and ok forget the changing to obd2 is there any way to make to put a 94 pcm in my car and mak it work so i can get a dyno tune
Old Dec 22, 2007 | 10:12 AM
chasmosis1's Avatar
You want to convert to a 94-95 ecm, OBDII started in 96.
I am unfaniliar with the 93, and I see that you were already advised in another thread that it cannot be done. If it can be done, it is probably just up to how many parts you are willing to replace. I'm sure you would need to change your engine wiring harness, but I am not sure of what other parts you may need, i.e. O2 sensors, MAF, MAP, Opti.
Once again, I know nothing about the 93 and this is all just speculation. I am just helping you to correct your terminology so that you might get the answers that you are looking for.
Chas
Old Dec 22, 2007 | 11:33 AM
You'll need a 94-95 PCM and engine wiring harness and maybe a few wiring modifications to get power and ground to the places they need to be.
Old Dec 22, 2007 | 06:30 PM
sbs's Avatar
sbs
Originally Posted by 93camarochrisz28
iwhen i said like a 94 i meant one that was able to get dyno tuned ...is there any way to make to put a 94 pcm in my car and mak it work so i can get a dyno tune
You seem to be under the mistaken impression that a 93 cannot be dyno tuned.
Old Dec 22, 2007 | 11:15 PM
the shops that i have been to say i need to get a chip burned for my car
Old Dec 22, 2007 | 11:18 PM
96m6lt1's Avatar
i beleive you will also need an instrument cluster from a 94-96 also
Old Dec 23, 2007 | 12:06 AM
sbs's Avatar
sbs
Which is irrelevant to whether you can have your car dyno tuned.
If the list of mods in your sig is current, then why do you need a dyno tune anyway? Get a mail-order tune.
Old Dec 23, 2007 | 09:02 AM
i have read on here that ut us better to get a dyno tune and i already have started to get my stuff ready to get le1 heads and le2 cam so i would like to get that set up dyno tuned thats why i started to ask about changeing everything
Old Dec 23, 2007 | 09:17 AM
Yes, 1993s require another chip to change programming. 1994s and later use flash programming.
Old Dec 31, 2007 | 09:13 AM
96HawkCnvt's Avatar
Yes, that's true but you need to find a shop that has an emulator and an eddy current dyno. If they know what they are doing they'll be able to dial it in even better with the '93 since they will be able to do it real time with the emulator. To my knowledge, that cannot be done with '94-'95 style computers (for LT1).
Todd
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
InfernalVortex
Jan 17, 2015 09:35 AM
blac94Z
Jan 16, 2015 05:07 PM
Sandersen511
Jan 13, 2015 03:49 PM
