Wheel Studs?
Old Dec 21, 2007 | 11:49 AM
LT1CST's Avatar
Wheel Studs?
Can someone help me out. I need to put in longer wheel studs on my 4th gen. Reason? So that I can run ET streets. I have a Rim that will not clear my Caliper. So longer studs with spacers I think will do the trick. I need to put longer studs in anyway. How do I do that?
Chris
Old Dec 21, 2007 | 11:56 AM
SS MPSTR's Avatar
Chris
just rears? remove caliper and hammer them out. use a heavy hammer to provide backing to the rotor. install new studs (12M x 1.50" x length desired) with a sacrificial nut, a few washers and an impact gun. use a little white grease on the threads prior to cinching them into the rotor.
and get a wheel that does clear the caliper, or clearance the caliper a bit. do not run spacers on the rear.
Old Dec 21, 2007 | 12:38 PM
n2ceptor's Avatar
FAQ in the Wheel/Tire Section has pictures... Not sure if there is a write up.....
Old Dec 21, 2007 | 12:58 PM
LT1CST's Avatar
Yeah im sorry. I meant to say spacers for the front. The rear ET rims clear just fine. Its the front that I need to run spacers. OK after I hammer them out. How do I get the new ones in? Who sells them? About how much do they cost.? How long is labor you think.
Chris
Old Dec 21, 2007 | 01:07 PM
SS MPSTR's Avatar
Chris
I just put mine on and it took me ~20 minutes per wheel. Summit, Thunder, Jegs - they all sell them and you'll need open end lug nuts to go with them. the new ones push in from the back, put a few washers on with your grease, and put on your sacrificial nut to 'pull' the lug into the rotor (it's a press fit). Use either a socket/ratchet/breaker bar to get the proper leverage, or an impact wrench. when the seat hits the back of the rotor, it is installed.
Old Dec 21, 2007 | 01:57 PM
Please post on correct fourm.... Moving to "Wheels and Tires".
Old Dec 21, 2007 | 04:30 PM
LT1CST's Avatar
I called J & M SPEEDCENTER in Riverside and they have them. Its gotta be orderd. Im trying to make the a Irwindale Race on the 10th of Jan 08. I havn't ran my car since the PSCA after I first built my motor. (it was not pretty). I gotta redeem myself.
Chris
Old Dec 23, 2007 | 01:25 PM
stopthatman's Avatar
on my LT1, i had to pull the axles to get the rear studs. what a bitch i heard the LS1 years don't have to and their studs are longer to begin with
HarleyZ28
Oct 5, 2015 06:23 AM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
Catmaigne
Dec 25, 2014 12:16 PM
Ken95Z28
Sep 15, 2002 12:37 AM
