any way to remove caked on brake dust from salad shooters??
Old Nov 17, 2007 | 04:42 PM
rawbutt's Avatar
well, i finally did it....waited to long to wash my car and now i can't for the life of me get the brake dust off my stock rims. for years, i've used armor all's wheel cleaner and it's always taken it right off...just like it was never there, but this time, the brake dust has been caked on for quite some time...especially on the front and after like 8 seperate applications of the tire cleaner tonight (waiting 5 minutes and then scrubbing each time), it still won't take it all off and it looks crappy.
anybody ever been able to overcome this or am i stuck with it now ? =/
robert
Old Nov 28, 2007 | 06:49 AM
Mellowdork's Avatar
Once I got into my mother in law's garage and got some "mean green" worked great on my wheels and tires. Its a multi purpose cleaner for the house. Just dont get none on your paint
Old Nov 28, 2007 | 07:03 AM
rawbutt's Avatar
i will try anything at this point, mean green is next on my list. i'm assuming it won't harm the stock wheel, clear coat, etc. ?
Old Dec 20, 2007 | 06:33 AM
Future_Z_Owner's Avatar
Mean Green or Simple Green should do the trick. I think the salad shooters are powder coated. I dont think you are going to hurt it with that cleaner.
Old Dec 20, 2007 | 08:46 AM
rawbutt's Avatar
i bought some simple green, bot it home and was just about to spray it when i read on the instructions to not use it on aluminum wheels....so i haven't yet. but i'm so tired of looking at the nasty wheels, i might have to try it anyway and risk it!
thanks for the replies...i thought this thread was dead long ago
Old Dec 20, 2007 | 11:15 AM
96m6lt1's Avatar
you can use it with water to delute it a bit ,i prefer purple power,water and a sponge use on cold rims!!!!!!!!!!!
Old Dec 20, 2007 | 12:06 PM
Moshbmx1's Avatar
i use simple green with plenty of water...hasnt hurt my rims yet, both on salad shooters and the Zr1's.
Old Dec 20, 2007 | 01:39 PM
rawbutt's Avatar
just wanted to report that i picked up some simple green at lowe's today and sprayed it straight on my warm rims (full strength)...let it sit about 2 minutes and then wiped w/ sponge and rinsed. there isn't a trace of any of the old brake dust that wouldn't budge before!! after reading some of the other posts here, i probably was pushing it spraying it on full strength and probably won't do that again. hopefully i didnt damage them (appears to be fine). in any event, just wanted to thank u guys for the advice. i'm so jacked to have clean rims again!
robert
Old Dec 20, 2007 | 10:30 PM
JC95Z's Avatar
Jus thought I would throw my 2 cents in here.I work at a body shop and after the cars are finished and get detailed they spray Meratic acid on the rims with a spray bottle and by the time you spray the last rim and rinse the first one off,doesn't matter how much junk was on them they are spotless.You would think it would hurt the rims but it doesn't.(Just your lungs.lol)
Old Dec 23, 2007 | 04:38 AM
bmotwani's Avatar
Surprised armor all couldnt fix it. It cleaned up mine which was years of caked on dust with just one application.
Old Dec 24, 2007 | 10:56 PM
Andrew R's Avatar
robert
You lucked out, I did that to mine and it damaged the finish on one of my wheels.
Old Dec 24, 2007 | 11:00 PM
6SpdLT1Z's Avatar
I was going to say simple green or some Eagle all wheel and tire cleaner and a wire brush.
Old Dec 24, 2007 | 11:05 PM
Andrew R's Avatar
A wire brush? Wouldn't that scratch the hell out of the wheel?
97znebr
Parts Wanted
Apr 12, 2015 02:31 PM
blac94Z
Wheels and Tires
Apr 7, 2015 12:46 PM
Timberwolf
Sep 2, 2002 10:42 AM
94bird
Aug 23, 2002 07:40 PM
jp2002ls1
Aug 6, 2002 06:57 PM
