Dumbest question ever - skip shift
Old Dec 19, 2007 | 10:42 AM
silver97Z's Avatar
OK, both of my previous F-bodies were both autos.
Is the skip shift from 1 to 3, or 1 to 4? Mine just does not want to go from 1 to 3 smoothly at all.
Old Dec 19, 2007 | 11:16 AM
rcantrellz28's Avatar
1st --4th . It will lock out 2nd and 3rd. Get the CAGS eliminator, or you can still run your car without it plugged in , it will not throw a code, but one would be stored- not rendering performance. If you do just" unplug it" make sure to tape up the ends of the sensor( pig tail or plug in tranni).... use electrical tape. I just unplugged mine, and its been fine for 4 years now , no issues----
Old Dec 19, 2007 | 12:00 PM
Bad info. He has a 96. OBD-II will set a code, and turn on the SES light if you pull the harness connector.
With your OBD-I 95, you will get DTC 84, but no SES light
Old Dec 19, 2007 | 01:13 PM
sorry Injuneer,you are absolutely correct-- my bad totally, need to slow down my reading/before posting lol..... OBD2 is different and it is noted in his sig...... again oops!!!!
Old Dec 19, 2007 | 01:20 PM
jerminator96's Avatar
I just removed the mechanism entirely everytime I rebuilt a tranny. It's still plugged in, it just doesn't do anything
Old May 15, 2008 | 10:14 PM
davieboy_70's Avatar
I want to remove mine too.
I wanna remove my skip shift and put a resistor in it BUt I dont know which one it is??? I just put in a new clutch so i'm not that dumb But I'm just not sure which sensor is the one to unplug Can you tell me??? It seems like you know alot about this.
Old May 15, 2008 | 10:53 PM
Do a "Search".... I've posted a drivers side view of the tranny numerous times, with the skip shift solenoid (its not a "sensor") labeled, along with the other components on that side of the tranny. Its right under the shifter, topmost/rearmost device.
Old May 15, 2008 | 10:54 PM
acre's Avatar
So they have this cool function on this forum called "search"
ok, I'm being a jerk, but seriously, this was the seventh thread (including yours) in a search for "skip shift." All the info you need is there. Pick your method, and go with it.
https://www.camaroz28.com/forums/sho...ght=skip+shift
I went one step further and took out the bulb for the skip shift light in the instrument cluster.
Old May 16, 2008 | 09:17 AM
silver97Z's Avatar
You fail at reading.
I'm not sure if this was directed at me or not, but I did use the search fuction...been here long enough to figure that out.
Also, the original question was the skip shift sequence...1st to 3rd or 1st to 4th...not how to eliminate it.
Old May 17, 2008 | 02:04 AM
acre's Avatar
I was replying to davieboy_70's question about how to eliminate it, since he resurrected your thread, but I guess since he threadjacked, I probably shouldn't have replied... I probably should have quoted him, but I figured my post would be right under his, but Injuneer beat me to the post.
Speaking of Injuneer, why don't you give him grief?? Oh probably because he's one of the most helpful people here and I'm just some new jerk...
Anyways sorry if my smart aleck answer made you mad, it was not directed at you.
Old May 17, 2008 | 11:13 AM
No one was responding to you... the thread sat dormant for 6 months... davieboy resurrected it from the dead, and we were trying to help him.
Old May 19, 2008 | 06:10 PM
silver97Z's Avatar
Sorry...I took it the wrong way I guess.
And I didn't get offended at Injuneer 'cause he didn't try to be a smart aleck
Sergio
Jan 27, 2016 04:27 PM
cmdeshon
Dec 27, 2014 10:06 AM
Jul 4, 2005 05:00 PM
SLIMJIM
Jan 7, 2003 11:06 AM
Mykdiver
Aug 13, 2002 05:38 AM
