Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
stupid question about removing...
Old Dec 9, 2007 | 12:30 AM
sn8ke eatr's Avatar
fuel rails. i know it seems so simple but im trying to work in less then adequate light and its only like 30 degrees out. i took out the 2 bolts on top of each rail and the fuel lines are disconnected. i know the rails are attacted to eachother in the back but is anything else holding them on? they wiggle around but i cant seem to pull them up. is just the injectors plugged into them holding it on? or is there anything i missed? thanks for any help.
Old Dec 9, 2007 | 07:50 AM
KYWes's Avatar
Can't offer experienced help as I haven't done it but will ask some things based on Haynes manual.
Remove fuel lines. (done) This needs a special tool that can be had at most auto parts stores and Sears.
It then says to remove the injector electrical connectors, accelerator and cruise control cables, and anything else in the way.
The manual says after remove the retaining bolts and remove the fuel rails. On a different engine that I have I have removed the injectors, they were in pretty snug because of the seals. It required gentle but firm pulling to free the seals from their grip.
I don't know if this will help. Had to work under similar situation and know the frustration. Goood luck.
Old Dec 9, 2007 | 10:59 AM
Boosted_Z28's Avatar
The injectors are o-ringed at the top and bottom so the fit is snug. Try using a small pry bar and alternate lifting each rail a small amount in both the front and back. They will pop off.
Old Dec 9, 2007 | 12:53 PM
sn8ke eatr's Avatar
alright great, thats what i thought. im gonna go do it now that i finally have some light. thanks for the reply guys,
Old Dec 9, 2007 | 01:25 PM
OBE1 95Z28's Avatar
Good idea to take an air gun and blow the dirt off the intake around the fuel injectors before removing the fuel rail.
Old Dec 9, 2007 | 08:18 PM
mrmint69's Avatar
You should replace the o-rings everytime you remove the rails. There is an injector retaining clip if you want to remove any of the injectors from the rail. Use new engine oil to lube the new o-rings.
Old Dec 9, 2007 | 09:32 PM
For everyone responding, keep in mind that the 93 rails and hard lines are significantly different than all the newer LT1's.
Magenta_Hearts
Mar 5, 2015 07:01 AM
cmdeshon
Dec 27, 2014 10:06 AM
brentbrowning01
Dec 16, 2014 06:35 AM
ChrisFrez
Dec 15, 2014 03:09 PM
Brent94Z
Mar 21, 2002 04:44 PM
