How hard to change out window.
Old Dec 8, 2002 | 05:28 PM
BOWTYDE's Avatar
I got a ticket fot tint in my car. I wanted to switch the glass with a friend camaro to get it signed off, how hard is this? Should I just pay to have to taken off them to have it redone?
Old Dec 8, 2002 | 05:53 PM
The window is riveted to the window regulator and the regulator is riveted to the door. Maybe that will help you decide.
Old Dec 8, 2002 | 06:17 PM
BOWTYDE's Avatar
I think I need to replace the regulator anyways.
Old Mar 3, 2003 | 02:40 PM
SweetZRag's Avatar
Slow Power Window
Shoebox,
I have been having problems with my power windows operating slowly and with 225K miles on the car and based on everyone's postings, I bought 2 motors from Jason but after replacing the first one using your how-to, I found out it did not help. I now believe that most of the slowness comes from a need to generally clean the regulator and tracks and regrease everything. I have now removed the regulator and learned a few things that I thought I should share.
First on my 94Z convertible, the window is screwed to the regulator track using plastic grommets, not riveted. The dealer parts diagram shows a metal grommet backer which my car did not have and I have been having a problem with these screws coming loose. Hopefully the backer will make the connection more secure than just the factory original grommet.
Second, drilling out the large rivets that hold the regulator to the door frame was fairly easy and you can replace it with 1/4" machine screws.
I plan to put it all together tonight after I clean and relubricate. The only thing left is the switch so hopefully this will fix it.
Hope this info helps.
SweetZRag
Old Mar 3, 2003 | 05:37 PM
Yeah, I have noticed some slo-mo action on my window when it is real cold out. A clean and re-lube is probably in order.
Old Mar 3, 2003 | 06:08 PM
1994TransAm's Avatar
one time in my garage...
i was walking and tripped over a block of wood and put my elbow threw the driverside window!!!
it sucked to change, but it wasn't that hard. ..i'd redo the tint!!!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
jmadoll
May 27, 2015 07:13 PM
birdblack
Apr 20, 2015 04:24 PM
armedtrigger
Feb 24, 2015 08:30 PM
