Getting the hub on to the balancer?
Old Mar 3, 2003 | 02:19 PM
Rodrigues's Avatar
I cant seem to get the balancer on the hub (to seat on that ring) Any ideas?
Update, I stripped one of the threads on the hub trying to pry is on with the 3 bolts evenly, thats didn't work.
WHAT size bolt are the balancer bolts? I need to run a tap through it. 20 threads per inch?
Old Mar 3, 2003 | 03:30 PM
Rodrigues's Avatar
I got the hub on, the bolts for the balancer are 7/16"-14 threads per inch.
The crankshaft is 20 threads per inch so don't assume they are the same!!!
Old Mar 3, 2003 | 03:33 PM
Sorry, I could have told you what the bolts were, but I did not catch up to the post.
Guess you got it fixed up.
Old Mar 3, 2003 | 04:11 PM
GREGG 97Z's Avatar
When I reinstalled mine I tried pulling it on with the stock bolts first too. I couldn't get them threaded in very far and one of the bolts stripped a couple threads off the end. I then found some thinner, longer bolts and put nuts and washers on the end and slowly pulled it on that way. I was a bit of a PITA. Are you sure the thread in the hub stripped or just the bolt? I think the bolts were made of a lesser grade steel, at least it seemed so since the bolt stripped on me and not the hub threads. After pulling it on with the longer bolts I cleaned up the thread on the one I stripped and was able to pull it on all the way with the stock bolts.
Old Mar 3, 2003 | 04:49 PM
Rodrigues's Avatar
The hub threads stripped. I was able to unscrew the threads from the bolt... LOL. I tapped the hub and used a die set on the bolt and its fine now. I grinded down the edge of the circular part of the hub because I used a hammer to try and put the hub itself on and it ruined the very edge. I hope that didnt ruin the balancing, I bought a new hub already from somone online so the next time I take it off I can install the new one.
Old Mar 3, 2003 | 06:10 PM
anaik's Avatar
Should have lightly sanded the ID of damper and the section that it mounts to, and used anti-seeze for the next time.
AviatorDave
Dec 19, 2016 06:35 PM
Jeff1904
Jun 5, 2016 05:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Boss002
Jul 24, 2015 10:47 AM
RallyRed701/2
Jul 20, 2015 11:18 AM
