Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
42# injectors ok for na 383?
Old Oct 15, 2007 | 08:13 PM
mrz28 73/97's Avatar
I'm building a na 383 with fully ported AFR 210's and Edelbrock airgap LT4 intake, cam selection dependent on final flow numbers of the heads but will be hyd roller. I'm thinking of getting 42# injectors along with a custom tune do you guys think they will be too big?
Old Oct 16, 2007 | 01:10 PM
The only thing that would make an injector "too big" would be if it was so large that the PCM drivers could not "turn it down" to the tiny pulse widths required for idle. The stock PCM has demonstrated an ability to provide a smooth idle with the 42 #/Hr injectors. If you plan to make more than 500 flywheel HP, the 42's are almost mandatory.
Old Oct 22, 2007 | 08:47 PM
Thanks Fred that's what I was thinking but I wasn't sure, I feel better now.
Old Oct 30, 2007 | 11:46 AM
Black6spdZ's Avatar
i run 42s with my setup with no issues at all.
Scott
Old Oct 30, 2007 | 01:03 PM
firebirdStud's Avatar
ditto. I have 438rwhp and using bosch 42#'ers. (they are the green top ford ones, but ford had nothing to do with them, bosch just stamped the crappy blue oval on them. )
It idles great, and man does she fly!
385 bottom end, AI top end.
I think you already got your advise though! hehe.
Old Nov 17, 2007 | 10:26 PM
ssean92's Avatar
who did your all mail order? I was planing on just getting a mail in update with madz
Devinfoote87
Feb 12, 2016 03:21 PM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
realistyc
Jul 28, 2015 07:32 PM
alphaauto
Jul 26, 2015 04:40 PM
Anon
Jul 23, 2015 12:18 PM
