Siphoning out gas.
Old Oct 15, 2007 | 09:13 AM
Canuck wita WS6's Avatar
Siphoning out gas.
Is there an easy way to siphon gas out of the tank?
I can't seem to get a hose down the filler neck, i guess there are too many bends, or possibly some kind of safety/security device.
Disconnect one of the fuel lines under the car and suck it out? If so which lines.
Old Oct 15, 2007 | 09:30 AM
Ok4thGen's Avatar
how much gas do you need out of the tank? Like completly empty or just enough to make it managable?
Old Oct 15, 2007 | 09:49 AM
Well i would like to get as much out as possible. I have year old gas in there, and i can't run the car to burn it. So i want to get the old stuff out before it gets too cold and it has to sit in there for another winter.
Old Oct 15, 2007 | 12:39 PM
Disconnect the line at the fuel filter and use the fuel pump prime connector to run the pump to pump out the gas.
Old Oct 15, 2007 | 12:58 PM
If you are persistant, you can get the siphon hose all the way down into the tank, and get most of the fuel out. I have done it several times.
Old Oct 15, 2007 | 07:11 PM
wrd1972's Avatar
Stick the hose in the hole, place hose in mouth and suck till you get a mouth full. Drop hose in bucket and don't forget to spit. It will work.
Old Oct 15, 2007 | 07:55 PM
Ya i've tried to get the hose down there, but it seems to get jammed on something not too far down.
Thanks for the ideas all.
68camaroboltz
Oct 5, 2015 01:46 PM
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
gonzo275rltw
Jul 10, 2015 11:47 AM
Chode89
N2O Tech
Aug 13, 2002 12:47 AM
