Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Opti problem
Old Oct 1, 2007 | 12:05 AM
henryz28's Avatar
Opti problem
When I did my cam swap I changed my opti with one from Auto Zone. The car has ran fine. But for the last two weeks when I go wot it pops and bogs. One other thing is if I let off real quick and put it back to wot it clears up. My guess is the Auto Zone opti.
Old Oct 1, 2007 | 12:23 PM
What year is your engine? Without that, you are limiting the ability of people to help you. If its a 95-97, did you check the length of the dowel pin, to insure it isn't pushing on the Opti?
Why not add a "signature" with basic infor about your car, year, model, tranny type and any major mods. Thart will help people answer your questions.
Old Oct 1, 2007 | 03:07 PM
roguedriver's Avatar
What Fred said. In case your wondering about the AutoZone opti's, i had one on my car for quite a few miles with no issues at all. But Fred is right. Some years had different length dowel pins on the cams. If you got a cam with the longer dowel pin and you needed the shorter pin (the length isn't much different, but makes a huge difference with the opti) then when you bolt the opti back up, it will run good for a short time but tear up the opti fast, then start running like garbage.
Ken R.
Old Oct 1, 2007 | 06:05 PM
henryz28's Avatar
I checked the length eventhough I ordered the cam for a 1996 and it was right. I did the cam about 10,000 miels ago.
Old Oct 2, 2007 | 02:23 PM
henryz28's Avatar
Sence my plug wires are origional I am going to replace them and return my opti for a new one. I was also thinking of new plugs right now I have champion plugs. What plugs would you guys use. Thanks
Old Oct 2, 2007 | 03:28 PM
White96Z28's Avatar
I like NGK TR55's for NA applications, but a lot of people swear by Autolites... I think those are the two that are most common in the performance F-Body crowd.
greenzee28
Mar 26, 2015 09:13 AM
grabbem88
Mar 18, 2015 01:25 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Injuneer
Dec 15, 2014 09:36 AM
