AFR Eliminator Heads
Old Sep 25, 2007 | 02:04 PM
DevilsAddvocate's Avatar
Can somebody tell me a quick visual way to tell the difference between the "newer" eliminator AFR heads and the older castings? Thanks
Old Sep 27, 2007 | 01:56 PM
96lt4vette's Avatar
There may be a better way than this, but you can look at the oil drainbacks at either end of the head. The older ones just had a small hole that was basically at the same level as the rest of the cast surface. The new ones have cast indentations around the hole which are supposed to eliminate the oil return problems the old ones had.
If you have a micrometer, you can also measure the valve stems (new ones are 8MM).
Old Sep 27, 2007 | 02:16 PM
thank you sir
Victor Lamb
Aug 26, 2017 02:52 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
95chwagon
May 27, 2015 09:53 AM
pimpss96
Feb 12, 2015 01:28 PM
MadMav
Feb 6, 2015 11:02 PM
