serious problem
Old Aug 29, 2007 | 07:38 PM
rickjames343's Avatar
serious problem
My 97 z28 A4 has a problem. The car moves forward in every gear position, including reverse and neutral. It doesn't shift out of first at all, no matter what gear is selected. Say im driving at 20 mph, which is about 2K, and let off the gas, it drops to an idle. Then i give it gas and it revs til about 2K (or whatever RPM according to the speed) and will finally catch. It NEVER shifts out of 1st though. Any ideas?
Old Aug 29, 2007 | 08:24 PM
12SCNDZ's Avatar
Your forward clutches are burnt so bad that the inside splined frictions have "welded" themselves to your outside splined steels. This makes the transmission "think" that the forward clutches are applied all the time.
Frank
CPT
Old Aug 29, 2007 | 08:34 PM
So...is it expensive to fix? And would that cause it to accelerate forward in reverse and neutral?
Old Aug 29, 2007 | 09:15 PM
Performabuilt's Avatar
Supporting Vendor
If it goes forward in reverse just like when in drive Im not so sure on the forward frictions, It would seem that if that was the case when you put the car in reverse rather than going forwad it would be like the brake was on , I am inclined to think there may be a linkage issue here and definatly worth checking first, I would drop the pan and verify that the linkage is ok . I assuming the car does stay still in park . which would elimiante external linkage. I would definatly look into that first.
Old Aug 29, 2007 | 09:20 PM
About park...it stays, but my dad says it feel like it tries to go. it wont rev past 1500-1800 in park though.
Old Aug 29, 2007 | 11:02 PM
Supporting Vendor
I would still drop the pan and check the internal linkage in particular the linkage wire/rod I have seen them broken etc, While its true you may find nothing and need a trans anyway. Its worth a quick look for sure.
Old Sep 4, 2007 | 09:10 PM
Okay well my dad and i checked the linkage...how expensive are the foward clutches to ge fixed? Would my best bet be to get it rebuilt?
Old Sep 4, 2007 | 10:18 PM
Supporting Vendor
Your best bet would be to get it rebuilt or buy a built unit.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
PCLZ28
Dec 24, 2015 05:19 PM
edxiel
Jan 24, 2015 07:40 PM
