Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fresh Air Line for MSD Opti
Old Aug 29, 2007 | 08:28 AM
94greenbandit's Avatar
Has anyone who has installed an MSD Opti run into the problem of installing the fresh air line into an aftermarket intake elbow.Since they tell you to drill a hole into the rubber and mine is aluminum not sure how to go about this.
Old Aug 29, 2007 | 09:56 AM
Drill a hole in the aluminum, tap threads into it, screw a thread-in nipple into the hole and attach the hose to the nipple. Or, drill a hole in the aluminum, put a rubber grommet in the hole, and get a plastic elbow similar to the stock blue piece, and push it into the grommet.
Old Aug 29, 2007 | 10:37 AM
Sounds like I will drill, tap and screw the nipple into the hole. Thanks for the help
RUENUF
Mar 13, 2016 03:39 PM
armedtrigger
Feb 24, 2015 08:30 PM
95chwagon
Jan 13, 2015 09:19 PM
ReznorZ28
Aug 27, 2002 03:53 PM
