running maf on pressure side?
Old Aug 27, 2007 | 09:28 PM
blownbird01's Avatar
Is there anything special I need to do to run my maf on the pressure side? I want to get it off the intake so I can be more creative on running the inlet for my d1sc.
Old Aug 28, 2007 | 12:25 AM
Chrisbequick's Avatar
There's nothing special as far as mounting. Just put it inline.
-Chris
Old Aug 28, 2007 | 07:06 AM
cjmatt's Avatar
just make sure that its got a straight path before it, mafs dont like to run right when theyre put right after a bend
Old Aug 28, 2007 | 07:34 PM
will it cause problems with my existing tune? I was'nt sure if anything had to be changed in the tune being that its on the pressure side now.
Old Aug 29, 2007 | 07:22 AM
cjmatt's Avatar
no it'll probably run better, i had mine on the suck side of my vortech setup and itd buck in the parking lot going slow, now itll idle smooth at 5mph
Old Aug 29, 2007 | 12:58 PM
mzgp5x's Avatar
Question...
If the engine crankcase vac system is plumbed to the suction side of the compressor, will the oil fowl the MAF hot wire sensor? I would think an oil separation unit/ tank would be a critical piece of hardware for the pressure side located MAF. B.
Old Aug 29, 2007 | 05:46 PM
Where do I find 3-3.5" rubber couplers to install the maf in my plumbing?
Old Aug 29, 2007 | 08:10 PM
snorkelface's Avatar
Originally Posted by mzgp5x
Question...
Yes. If you have your EVAC plumbed that way, you should have an oil/water separator anyway. You don't want oil going into the intake tract of your FI motor, MAF or no MAF.
Old Aug 30, 2007 | 05:56 PM
Ultra_Dog's Avatar
Napa Parts.
I bought a 3.5" ID hose and used it as a sleeve for the 4" hose.
DirtyDaveW
Dec 1, 2016 05:37 PM
pete53
Dec 9, 2014 07:31 AM
formula218
Dec 2, 2014 04:27 PM
Jul 4, 2005 05:00 PM
RedLineRev
Jan 23, 2003 03:51 PM
