Tooled by bad wheel hub bearing, whats your opinion?
Old Aug 25, 2007 | 05:16 PM
jclark311's Avatar
My hub bearing went bad last night, but before it went there were some warning signs. First it sounded like the tires whining on a 4 wheel drive, but not so loud. I attributed that to some used tires i had bought and put on the back to burn off, (when my i install my new motor). Then for a day or so, the brake pedal was real soft, i figured the master cylinder was going, i have 70k on her. Well it turned out to be a bad hub bearing. This is what i think happened, i had rotated the tires a while back, there were no arrows on the tires showing direction, i think i put the front 2 on backwards. That caused a vibration, and that broke the bearing after time. What do you guys think?
Old Aug 25, 2007 | 07:54 PM
I don't think that explanation is plausible.
Old Aug 25, 2007 | 09:39 PM
jclark311's Avatar
Well than that wheel bearing must have just went, at any rate, i should have caught it way earlier, i only drive the car on weekends, and my daily driver is a 4 x 4, i guess i was so used to driving the truck, that i didnt even notice the car making more noise.
HectorM52
Jul 30, 2017 11:46 AM
warmeck
Mar 8, 2015 08:01 PM
cyteone
Feb 7, 2015 06:04 PM
1996LT1Z28
Dec 1, 2014 01:01 AM
