Window sweep replacement
Old Aug 22, 2007 | 09:14 PM
Zoid's Avatar
I need to replace the dry rotted and cracked outside window sweeps on my '84. Two of the screws that hold the strip to the door are behind the window glass. Window up or down, I can not get to these screws. Are there ay "tricks" to get to them, or do I have to remove the window just to replace the strips??
Old Aug 22, 2007 | 09:44 PM
Dave89IROC's Avatar
not remove the glass, but you need to take it loose so it will lay lower in the door
Old Aug 24, 2007 | 06:36 PM
Zoid's Avatar
I was able to remove the strip by taking off the two top inner window guides. That gave me about an extra 1" of room -enough to use a right angle screw driver. I also had to remove the triangle filler plate at the front of the door by loosening the front guide assembly. There was one screw behind that plate.
Keenan
Jan 19, 2023 12:24 PM
dale3in98
Feb 14, 2015 12:18 PM
warmeck
Feb 2, 2015 12:44 AM
Jazsun
Dec 29, 2014 12:14 PM
