SES light when driving long distance
Old Dec 2, 2002 | 10:47 AM
Achilles97's Avatar
Question SES light when driving long distance
I occasionally get an SES light when I drive long distances on the Interstate. I wait about 5 minutes, then restart the engine and the SES light is no longer on.
I scan for codes and there is no code, but I've only scanned it when the SES light is not on anymore.
What do you think this could be? I think it could be running rich, or my O2's are screwed.
Any ideas?
Thanks!
Old Dec 2, 2002 | 11:10 AM
RENE95Z's Avatar
I had a similar problem until I read a post about taking of the MAP sensor and give it a little cleaning. I haven't seen the SES light since then.
Old Dec 2, 2002 | 11:20 AM
JBirdSS's Avatar
Change your fuel filter.
Old Dec 2, 2002 | 12:24 PM
n2ceptor's Avatar
I had a similar prob, but it was the EGR valve. Replaced it a no more SES...
93Z Will
Old Dec 2, 2002 | 01:01 PM
Achilles97's Avatar
Hello,
Thanks for the replies.
I changed my fuel filter about 2000 miles ago.
I don't have an EGR system.
I'll check out the MAP sensor.
Thanks!
Old Dec 2, 2002 | 06:14 PM
scoobysnax83's Avatar
Did you remove the egr system, cause stock, we have one!?! Just curious...
Old Aug 28, 2003 | 10:22 AM
CobraEatr's Avatar
I'm having the exact same problem. The light only comes on during long trips on the interstate. I think it has something to do with us removing the EGR system. It's been happening to me for 3 years and I keep perfect maintenance on everything, so I know its not the fuel filter, O2s, etc. Let me know if you find out anthing.
Old Aug 28, 2003 | 01:53 PM
You should definitely start this again in a new post. The last time someone viewed this was in December of last year If you want to reference this post just copy the link and paste it into your post. You will get a much better response from that. Good Luck...
Old Aug 28, 2003 | 03:09 PM
350 HRSS's Avatar
Originally posted by Achilles97
Hello,
Thanks!
If it hasn't been disabled, you can still get a code, or SES light. I had that problem before tuning.
How long has it been since you have done 02's? If it has been over 20k, get new ones and see.
Good luck, and post your results!
Old Aug 28, 2003 | 04:08 PM
CobraEatr's Avatar
I replaced my O2s about 5k ago. I always change all fluids, sensors, etc. when they are due. It has to be an EGR code. Looks like the only way to get rid of it is to get some tuning done.
Gtpguy
Jan 26, 2015 04:50 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
Doug Harden
11
Jul 14, 2002 04:31 PM
