Long Tube Guys.... Does your starter get to hot?
Old Aug 25, 2003 | 09:30 PM
Smokn '94 Z's Avatar
Question Long Tube Guys.... Does your starter get to hot?
I have been having issues with my starter getting to hot from my Long Tubes. There is plenty of clearance IMO & I even have a heat wrap on the starter. When I start the car when cool it fires right up. However if I am driving for about 20 minutes, then shut the car off for 5 minutes, then go to start it again it has a very hard time starting. (Almost doesn't) I am assuming that the starter is getting sever heat soak from the LT's. Anyone expierience this? The starter has been re-built.
Old Aug 25, 2003 | 09:59 PM
ltlhomer's Avatar
The starter is probably one of the only things I have been blessed not to have a problem w/ so far.
Sorry to hear you're having a problem though. G'luck w/ coming up w/ a solution.
Old Aug 25, 2003 | 10:03 PM
Rodrigues's Avatar
Mine cracked in half from longtubes, went with the LT4
Old Aug 26, 2003 | 11:33 PM
D James's Avatar
my solinoid went after the longtubes, but has been working great ever since the new one, it was only 25-30 bucks, so not such a big deal, yours sounds pretty annoying to deal with, don't they make a plate to go over it like other engines?
Old Aug 26, 2003 | 11:52 PM
CamaroBoy96Z28's Avatar
I dont think I was having problems with my starter but for insurance I went to a DEI versa shield. My Z fires up every time and now even better with a new fuel filter. It also seemed to fire up better when the car was warm as well.
Old Aug 27, 2003 | 01:06 AM
Kain's Avatar
I've never had a problem.
Old Aug 27, 2003 | 02:42 AM
a_z28_vance's Avatar
No problem here. I've been using the lt4 for about two years now.
Old Aug 27, 2003 | 03:22 AM
Vegas25thTA's Avatar
i haven't had any problems yet either..i have jet hot long tubes and the only think i messed up was i burned a couple of spark plug wires in half...
Old Aug 28, 2003 | 04:23 AM
revtime's Avatar
I notice you have FLPs, I have Hooker jet hot coated LTs and I have not seen a problem with heat soak. It has been very hot here in KC as well and no problems with the starter.
I too bought a DEI heat shield thinking I might have a problem with the starter but so far not a hint of heat soak.
That heat shield is sitting there just in case I ever need it.
Old Aug 28, 2003 | 04:20 PM
Well I am starting to think my starter is tired...... It is original & maybe not liking the heat. It is clear of the headers by a good solid 2" or more.... I dunno... I hate seeing some friends after a long drive then have to start the car again. It almost doesn't turn over..... Kinda embarrassing....
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
drptop70ss
May 4, 2015 08:22 PM
LT14LIFE
Feb 9, 2015 09:35 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
