Panhard??
Old Aug 4, 2007 | 02:56 AM
OneFreakZ's Avatar
Unhappy Panhard??
i have a adjustable panhard i wanna install but how do i know when the wheels are centerd for my 94 z28 17x11wheels i know the drivers side stick out alittle more than the ps does what are the messurements to when there center??..if i buy relocators for the lca do i need to have the adjustable lca or not??..thanks
Old Aug 4, 2007 | 06:16 AM
380ss's Avatar
I used a plumb-bob. Basically it's a string with a weighted object tied to the end (like a nut or a screw). I taped that to the outside of my fender and allowed it to hang down. Once it stopped swinging, I measured with a ruler the distance from the wheel to the string. I did the same on the other side and basically adjusted the pan hard bar until my measurement was balanced between the two strings. Hope this helped
Old Aug 4, 2007 | 10:52 AM
If you add LCA relo brackets, you do not need to get adjustable LCA's. The relo brackets have the holes arranged in a slight arc, so that the stock LCA length will work no matter which hole you use.
Old Aug 4, 2007 | 11:11 AM
OneFreakZ's Avatar
i got aftermarket lca but not adjustable how do u know which hole to use i mean is there like a difference??which hole do i use??..thanks
Old Aug 4, 2007 | 11:58 AM
The theory is to drop the axle end of the LCA until it is slightly below the other end on the body. If you could do that with the first hole, it will be OK. In practice, I just put mine in the lowest hole.... actually Steve Spohn just put them there. But my car is pretty much "track only", so I don't know if that is the preferred approach for a street driven car.
http://www.injuneer.com/images/photo.../DCP04293a.jpg
Old Aug 4, 2007 | 06:30 PM
krisb410's Avatar
What kinda sway bar setup is that, sweet lookn endlinks?
Old Aug 5, 2007 | 12:44 AM
Spohn Pro Series Rear Drag sway bar.
http://www.spohn.net/product.cfm?productid=1437
Old Aug 10, 2007 | 07:57 AM
Norm Peterson's Avatar
It's a good idea. If the holes in the specific set of LCA relo brackets are a little "off", being able to tinker with the lengths of adjustable LCAs is the simplest way to cope with this. Same need for adjustability goes for brackets (even "perfect" ones) that have been installed less than perfectly.
Norm
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
football4life
Oct 4, 2015 07:48 AM
Henson071
Sep 18, 2015 04:01 PM
Slayer
Aug 17, 2015 03:55 PM
