please help, can't get tranny to come out
Old Aug 3, 2007 | 01:46 AM
blknblu's Avatar
I have been trying to pull the tranny in my 97 ws6 all night, I have it "hanging by a thread" and if feels like it could almost fall but it just won't let loose. It is split almost an inch from the block but it just won't come any further. Any suggestions?? I don't have a lift, I am just using jack stands so that makes it more difficult.
Old Aug 3, 2007 | 01:49 AM
Klypto's Avatar
sure you got the bolt out thats 12 oclock on the bellhousing? took us a long *** time to figure out that that held it in...
Old Aug 3, 2007 | 08:39 AM
pyro719's Avatar
6 bellhousing bolts and 3 torque converter bolts andit should drop.
Old Aug 3, 2007 | 11:45 AM
If we only knew what type of transmission it is...
The most common problem with pulling a manual is that people don't release the clutch fork from the throwout bearing.
Old Aug 3, 2007 | 01:24 PM
MEAN LT1's Avatar
Ive done that a couple of times.
Old Aug 3, 2007 | 04:23 PM
12SCNDZ's Avatar
There's no bell bolt at 12 o'clock on an LT1.
Frank
CPT
Old Aug 3, 2007 | 04:25 PM
blknblu's Avatar
sorry I forgot to mention that it is a manual, long night in the garage. I am guessing I didn't release the clutch fork...I just took off the clutch master cyl/slave setup (unless that is what you ment)
I oculd almost sping the tranny in a circle and it is very wobbley so it can barely be on there, the front of the bellhousing is even with, or a hair past, the back side of the ringgear on the flywheel.
Old Aug 3, 2007 | 04:50 PM
You have to reach in and pull the fork off the throwout bearing. Once you do that, the transmission will come out.
Old Aug 3, 2007 | 04:58 PM
dangalla's Avatar
yup you should be able to do it with one finger, just stick your finger in there and pull away from the trans towards drivers side of car
Old Aug 3, 2007 | 09:36 PM
rngilliland's Avatar
It looks like you are trying to remove the trans and bellhousing as a unit. I have always taken the trans off the bellhousing first and then the bellhousing off the block.
Old Aug 3, 2007 | 09:46 PM
wildweasel's Avatar
go inside and check the hole that the shifter came through. Seems to when i did it the tranny was catching there and I had to bend some of the sheet metal out of the way.
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
