when is it OK 4 Nitrous on a new motor?
Old Aug 2, 2007 | 08:53 PM
Wishmaster's Avatar
I still need a tune Im sure.....gotta a lsracingchips tune now..but when can I can start using NO without damage? the new motor has about 1600miles on it now.
when would it be ok for say a 100 shot?
Old Aug 2, 2007 | 09:05 PM
Z-RATED94's Avatar
So get a tune and then have them check it with the nitrous also if your putting it on the dyno. I'd say you were ready 1k ago.
Old Aug 3, 2007 | 09:12 AM
Ray@NitroDaves's Avatar
I was spraying mine on the intitial start up......J/K
I would wait until after the engine builders reccomended break in term....but with 1600 miles on it you are fine.
Old Aug 3, 2007 | 01:43 PM
We ran my brand new engine on the engine dyno for an hour with varying loads and RPM, drained/replaced the oil, changed the filter, checked all the torque specs, leaks, etc. From that point forward it was run through numerous pulls to set the NA tune, 125-shot tune and then the 275-shot tune. No "break-in", other than the one hour on the dyno. No damage , at least none that's apparent 7 years later.
Dmonty
Jun 2, 2015 11:19 PM
bandit383lt4
Dec 21, 2014 09:12 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
formula218
Dec 2, 2014 04:27 PM
