Torque converter questions
Old Jul 28, 2007 | 06:26 PM
NemesisLT1's Avatar
First of all, Im cheap, just wanted to clear that up.....
I am thriving for more power and I heard a Tq converter is the way to go.
So Looked on Jegs.com, and found some B&M Tork Master Converters
My first thought is that its B&M, name brand, cant be bad right?
Well for a 2000 stall its $232, and a 2400 stall is $256.....
1. Is this an okay converter?
2. 2000, or 2400 for me?
3. how is the install myself, will anyone help me, or whats a shop gonna charge?
4. Are there any other parts I need to buy for the install?
Old Jul 28, 2007 | 08:11 PM
exgmguy's Avatar
Most people will tell you to spend the money on a Yank, Fuddle, or Vigilante. Now that is out of the way......
I just installed a B&M 2400 in my car. It was a pretty easy job. The top trans bolts require about 18" of extensions, and the middle bolt on the drivers side comes out with a box wrench. The trans lines are also a little tough to get at, but not too bad. I jacked the car up evenly and supported all 4 corners with jackstands, Took off the driveshaft, torque arm, trans mount, and the drive shaft catcher-thingy. Took off the inspection cover, removed the flexplate bolts, linkage, electrical connectors, and finally the trans bolts.
I dropped the trans down just far enough to get the converter out, and the new one in. I put about a quart of fluid in the new converter before putting it on. Don't forget a good trans cooler as well.
I did it by myself in about 4 hours altogether.
The 2400 does not feel very loose. I would have definitely gone with a 3000 or 3500 if I were to do it again. It stalls at 2800 on my bolt-on car. If I power brake it will spin the tires around 1900 rpm. But if I just mash the gas, it flashes to 2800 and goes. Not too bad I guess considering the stock converter was so tight that it felt like the car was trying to push through the brakes at a stop.
With the stock converter, my car felt good in 1st and 2nd gear, but when it hit 3rd it felt like it fell off a bit. It seems to pull better in 3rd gear now. A little slippage keeps the rpms up I guess. As long as it locks up enough to keep my trap speeds up at the top end i'll be happy.
gt_biker13's Avatar
Dont bother unless its at least a 3000 stall. I have a 3200 and it might rev 200 RMP more then before around town. Its still very streetible. I had a shop put mine in when they rebuilt the tranny so im not sure about your other questions.
Old Jul 28, 2007 | 08:49 PM
TobyZ28's Avatar
I would say 2800+ I stepped up to a yank 2800 and the car is night and day compared to before. It also rev's a good bit more than 200 rpm than before too (perhaps itsa the brand?), and mashing the gas now reeeaaaly gets the car going at lower speeds.
Old Jul 28, 2007 | 09:19 PM
Z-RATED94's Avatar
There is a reason why most people stay away from that converter and a few others. The few that don't soon learn their lesson, or are the few percent that are lucky.
Old Jul 28, 2007 | 09:23 PM
Z-RATED94's Avatar
exgmguy, the converter does not lock-up under full throttle. Although some have set it up with a switch so it does. A single disc converter is not enough to handle this though and still last.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
ChrisFrez
Feb 15, 2015 07:49 AM
Collector Car
Dec 17, 2014 01:12 PM
squarehead
Nov 21, 2014 08:02 PM
RedLineRev
Jan 23, 2003 03:51 PM
