Sealing 2 piece jethot primary?
Old Jul 24, 2007 | 07:10 PM
Chvywolf's Avatar
I recently got my Hooker Super Comp's from Jethot and the passenger side #8 primary tube is 2 pieces slip fit. What would you guys recommend to seal this up as I don't want a leak. Split BLM's are a pain as it is, and I don't need to add to it with a leaking header.
Old Jul 24, 2007 | 08:59 PM
NVetro's Avatar
You my friend have just asked an age old question :-) Alot of people just say screw it and weld around it. Personally, when i installed it, i put some oil around the tube, put her in, and it doesn't leak. Some people have issues with it leaking, but I bet its a header bolt rather then that. Ghetto jb weld im sure works also :-D I've heard someone using high temp rtv, but that didn't work to well
Old Jul 24, 2007 | 09:19 PM
shock6906's Avatar
I smeared mine up with copper-safe high temp RTV. I have gone about 5-800 miles since the install and haven't had any leaks out of it.
Old Jul 27, 2007 | 09:31 AM
wrd1972's Avatar
My slip fit does not leak at all. I have tried the copper RTV in the past and it just burned off. I have been working on a band clamp but I dont hink it is really needed.
Old Jul 27, 2007 | 09:38 AM
Chvywolf's Avatar
Thanks for the input guys
Ericksd
Jan 20, 2016 06:07 PM
93 RedBird
Nov 15, 2015 08:24 AM
colts0455
Sep 27, 2015 01:07 PM
Fatdog2
Sep 16, 2015 11:04 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
