Thump on takeoff
Old Jul 21, 2007 | 04:45 PM
galivan's Avatar
Thump on takeoff
I'm getting a thump on take off in my 2000 Z28 w/5.7L. It only happens when I start from a dead stop. The harder the takeoff, the more that you can feel/hear a thump. It doesn't happen any other time. I thought maybe it was a broken tranny mount, but it seems to possibly comming more from the rear, but I can't really tell. Can somebody give me their thoughts on what this might be?
Old Jul 21, 2007 | 06:01 PM
Moshbmx1's Avatar
Have you checked the tranny mount yet or just ruling it out beause it sounds like its coming from the rear?
Old Jul 21, 2007 | 08:13 PM
Greed4Speed's Avatar
A loose LCA bolt will do this too.
Old Jul 21, 2007 | 08:35 PM
showstoppers-96-Z/28's Avatar
This is more than likely the damned stock tranny mount, happened to me in my 96 Z/28 and my boy with his 95 TA, jack the front of the car up and take a peek
Old Jul 21, 2007 | 09:05 PM
NemesisLT1's Avatar
Ive heard of the tips/muffler hitting underside heat shield, LCA bolt, or tranny mount....
Old Jul 21, 2007 | 11:57 PM
galivan's Avatar
I haven't had a chance to lift the car and check it. My schedule doesn't allow for much free time, so I am hoping to get some ideas what it would be best to check first. One additional piece of info, that might be helpful, is that this started right after I was accelerating hard across a train track crossing and had severe rear wheel hop.
Thanks for the responses so far.
sn8ke eatr's Avatar
sounds like the tranny mount
Old Jul 22, 2007 | 12:12 AM
columbus's Avatar
As someone who replaced 2 while I had my Camaro, I would guess the tranny mount too. Man did it scare the crap out of me the first time though!
Old Jul 22, 2007 | 10:51 AM
reamo04's Avatar
i would say tranny mount too, i had the same thing
Old Jul 22, 2007 | 11:01 AM
94Camaro_Z_28's Avatar
I had the same problem, also thought it was a transmission mount. It wasn't. Turned out the nut on the bolt holding the panhard bar on the passenger side had jumped a few threads and was loose. I ended up having to cut the bolt off. Once I replaced it, the thump was gone.
Old Jul 23, 2007 | 12:13 AM
wrd1972's Avatar
Tranny mount
Motor mount
LCA bolts
Track arm mount or bolt
U-joint
Old Aug 4, 2007 | 03:19 PM
galivan's Avatar
Finally got a chance to look at this problem. I can confirm that it's not the panhard bar or LCA bolts. Taking a break ... Next step is to move my jack stands and check the tranny mount.
Old Aug 4, 2007 | 07:57 PM
galivan's Avatar
For those of you whose said tranny mount ... take a bow.
The rubber tranny mount was torn almost completely in half. I picked up an ES poly mount and now there's no more thump on takeoff. There is a marginal increase in vibration, but it is not severe. With the top down and the wind in my hair, I hardly cared. Besides, if I wanted a silky smooth ride, I'd have bought a Buick or a Caddy instead of a Z28.
Matt Dreessen
Sep 9, 2015 09:58 PM
KYWes
Aug 10, 2015 07:03 PM
JDohn2001
Jun 5, 2003 04:34 PM
OLDDIRT
May 30, 2003 07:06 PM
kartracer04
Feb 2, 2003 08:06 PM
