"Gauge" fuse blows when I put M6 in Reverse
Old Jul 15, 2007 | 08:09 PM
PoorMan's Avatar
Car in sig. Just finished M6 install from an A4. Replaced the engine harness with an M6 harness of the same year.
When I have the ignition on and put the car in reverse the 10 amp gauge fuse located on the left side of the dash blows every time.
I found an old post saying to replace the backup switch on the right side of the trans. Well, I replaced that switch today and my fuse still blows. Any suggestions??
JD
Old Jul 15, 2007 | 10:53 PM
I'll move this to "Drivetrain" since its not an "engine" question.
If the switch is OK, then it must be connecting a cricuit that has +12V on one side (supplied through the fuse) and a ground on the other = a short. Check your wiring.
Sergio
Jan 27, 2016 04:27 PM
PCLZ28
Dec 24, 2015 05:19 PM
jayvar
Feb 2, 2015 10:00 PM
Britbilly
Jan 7, 2015 08:49 PM
ChameleonGreen
Sep 2, 2002 05:15 AM
