wheel bearings
Old Jul 2, 2007 | 11:57 PM
pimarine21's Avatar
wheel bearings
I think my rear wheel bearings are going bad. How hard is it to change them and do i need any special tools? How much and long is a job like this. Any tips or advice to make the job easier would be great. 99 camaro ss
Dee
Old Jul 4, 2007 | 10:41 PM
popstoy's Avatar
you need a slide hammer type bearing remover you have to remove rear cover drain fluid ;remove calipers ,rotors then remove the c clips in differential, there is one bolt going through the center once removed the c clips should come right out with pliers.then slide out axle remove bearings.
Old Nov 11, 2007 | 08:14 PM
Oxygen454's Avatar
From what I have heard the hardest part is jacking up the car. All you need to do is remove the brake caliper. No draining required, just use a wire to hold the caliper setup so it does not detach the hose.
Old Nov 11, 2007 | 09:48 PM
Far from correct. The axles have to be removed to change the bearings, like popstoy said.
grabbem88
20
Dec 27, 2015 07:42 PM
akwa
Apr 5, 2015 05:09 PM
warmeck
Mar 8, 2015 08:01 PM
