ok got some questions
Old Jun 27, 2007 | 10:43 PM
camaro kid z28's Avatar
new here first post on this site. sorry about stupid questions. also not meant as spam but you guys may want to check out nastyz28.com lots of good info there.
i recently bought an LQ4 from my brother. he gave me an LS1 cam. two sets of stock pistons. pushrods. crankshaft (with 207K miles on it). i got the fuel injection setup and air intake. and pretty much everything else. putting it in a 79 camaro
now about my questions.
1.) if i switch to a carbuerated setup,which is my plan, do you still have to have a computer to run the coil packs. or is there a different type of ignition to buy.
2.) if there is a computer to run the coil packs, i that the only thing the computer will run or do i have to have the entire wiring harness.
3.) if at all possible i would like to switch to mechanical oil pressure, water temp, and other guages of the sort. where do i purchase these from.
4.) where do you purchase motor mounts and headers.
5.) is there any custom fitting I need to do to have my stock hood on it.
6.) do i need to make any modifications to the firewall.
if there is a lot of computer wiring to do i will just leave it as a fuel injected motor
im sure this same post has been made 100 times before me but i don't have time to search and find all my questions on the forum. any information would be greatly appreciated.
also if anybody has ever rear-mounted a turbo, information about that would be usefull to, or i may be the first person on the site to pull that one off.
__________________
1979 camaro z28, 80z28 , 78 gold edition TA
Last edited by camaro kid z28; Jun 27, 2007 at 10:52 PM. Reason: forgot to put in information
Old Jun 28, 2007 | 06:05 PM
Z28luvr's Avatar
If I'm not mistaken, MSD makes a kit to convert LS1s to a carb. Check out summit or jegs,.....or if one of the site vendors carries it, maybe they can chime in......
Old Jun 28, 2007 | 06:38 PM
i found a kit from edlebrock that has an msd ignition with it. but its 700$ ill get it if i have to but id rather look for a used one or a different one. i still have all of the other things to look into tho
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
