lower A arm help
Old Jun 27, 2007 | 12:04 AM
BMoney's Avatar
lower A arm help
ok I am changing out my K member, on my 96 Formula, I have everything un-bolted. but I cannot remove the rear bolt on the lower A arm. I have removed the nut from the bottom, but just cannot get the bolt out. is there a certain way to remove it??? it looks like you just remove the nut and pull the bolt up. I have hit it with a hammer and still nothing. any info would be great! thanks in advance
Brian
Old Jun 27, 2007 | 02:33 AM
BMoney's Avatar
update: I have removed the whole thing now, K member and the lower A arm. my lower A arm is still bolted to the factory K member. and I still cant get the bolt out??? I just dont get it. it must be seized in there or something. I cant afford to get new A arms right now so I need to get this bolt out.
Old Jun 27, 2007 | 11:22 AM
BMoney's Avatar
anyone know how to remove the rear bolt??? is it just supposed to slide out?
Old Jun 27, 2007 | 11:59 AM
multicar's Avatar
Yes, its supposed to slip out, but it gets crusty between it and the bushing inner sleeve. Try this: lightly heat the bolt with a propane torch, find a birthday candle and drip/run melted wax down the shaft of the bolt. That'll loosen it up.
Doug
Old Jun 27, 2007 | 12:34 PM
BMoney's Avatar
ok thanks. I just talked to a buddy of mine and he said the same thing that they get rusted up and seize together, so he said to try to heat up the bolt too. thanks for the help!
Old Jun 27, 2007 | 03:52 PM
v7guy's Avatar
PB blaster works great too, spray the hell out of it, let it sit, then smack it with a hammer.
Old Jun 28, 2007 | 01:39 AM
BMoney's Avatar
I finally got the bolts out! thanks for the help.
Old Jun 28, 2007 | 08:37 AM
Terran2k's Avatar
what did you use pb blaster or heat? I'll need to replace my lower ball joint and I may just remove the lower a-arm and have a shop press the ball joint out and in.
Old Jun 28, 2007 | 12:53 PM
BMoney's Avatar
a combination of both. soaked them with pb blaster, and then heated them up. I only have a little propane torch, but it worked!
Old Jun 28, 2007 | 01:23 PM
Terran2k's Avatar
thanks
Chevyguy358
Parts Wanted
Jul 20, 2015 07:42 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
94Form
Jul 17, 2015 10:56 PM
Noer
Parts Wanted
Jul 4, 2015 05:13 PM
