shifting problem
shifting problem
car was running fine untill i had the converter loosened up to aprox 3600 stall then i was running into problems with the computer and stall wall issue, sent out the pcm to get that fixed, now when i manually shift it, the car will bounce the limiter in first still after i shift into 2nd. and i shifted at 6200 rpm the limiter is set at 6800 rpm, but if i let it shift by its self it shifts fine,
what could be the problem
i also lost converter lockup
hold on, absolutly no problems shifting before i had the converter restalled, all they did was loosen up the converter and change fluid and filter(which i do once a year)
i want to say that they are set at 5800 when its in drive, it shifts fine in drive,
now today when i manually shifted to second at 6200rpm it shifted every time,
jb4xx
Feb 2, 2015 10:00 PM
This is really starting to sound like internal transmission issues.
