Potent Gas Fumes - Where To Look?
Old May 30, 2007 | 07:47 PM
MarcR94v6's Avatar
My car has been getting more and more fumey, especially after fill-up, which would be normal but it is very potent. I can handle it....sometimes, but passengers cannot. Anyone ever had this problem and can give me an idea where to look?
Old May 30, 2007 | 08:20 PM
matLT1's Avatar
I would start with inspecting your EVAP system from the gas tank to the engine. Make sure all hoses and fittings are attached. Also check for leaks in the lines as well as a cracked charcoal canister. If everything looks alright, it is possible that your fuel cap isn't sealing (can tell it isn't if you don't hear a hiss when opening it) or the canister may need replacement.
Old May 30, 2007 | 08:35 PM
MarcR94v6's Avatar
Dammit, I haven't been hearing a hiss when I open it ever since my original cap got stolen and I replaced it with a locking cap from Kragen...cheap P.O.S...
Old May 30, 2007 | 09:12 PM
MarcR94v6's Avatar
I no longer have the receipt, can anyone recommend me a name brand cap, locking or non, that served you well?
Old May 31, 2007 | 12:47 PM
Get the correct, NON-VENTED cap from Stant. But its more likely one of the problems described above with the EVAP system. A cracked hose would eliminate the "hiss".
94Maroz28
Oct 27, 2015 04:38 PM
68camaroboltz
Oct 5, 2015 01:46 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
drt
Sep 27, 2015 04:39 PM
jackpawt883
Sep 10, 2015 08:53 PM
