93 LT1 datalogging
Old May 20, 2007 | 10:17 AM
93BlackTA's Avatar
93 LT1 datalogging
I have a 93 Trans Am with 383. I want to do some datalogging and have tunerpro RT, laptop(only USB ports), ALDU1 cable and CABL1 cable....do i have to load a definition file in order to start data logging? can someone help me get everything setup please?
Old May 20, 2007 | 11:33 AM
93BlackTA's Avatar
ok, i hooked up the ALDL conector and turned on tunerpro....when i try to connect it tells me that "connection failed".....what do i look for? I know my ALDL port is working becase i get a code 12 when i cross out terminals A & B..no other codes present...
Old May 24, 2007 | 02:22 PM
Dennis93TA's Avatar
Download "Datamaster" and try that. that is what i used on my 93LT1. You get 20 free datalogs after that you have to buy the program.
Old May 24, 2007 | 02:23 PM
93BlackTA's Avatar
ok, thank you, i will try that
Old May 25, 2007 | 10:37 AM
93BlackTA's Avatar
that one's no good for me with a 93....but i'm sure i will work for someone with a newer car
Old Jun 3, 2007 | 11:14 AM
93z383's Avatar
yes you need the bin definition and the XDF for your spacific ecm, I can send it to you if you want.
Old Jun 3, 2007 | 01:48 PM
93BlackTA's Avatar
can you please send it to me....bmouland_@hotmail.com....Thanks
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
