before I do this, i wanna check..........
Old May 10, 2007 | 09:36 PM
hey01's Avatar
im going to get an electric cut out, and i was thinking of just putting it flat our right after the Y-Pipe connects.
I don't have a cat so thats probably where it would be hanging out at.... I know everyone puts their cut out way back by the axle, so im wondering if anyone has ever done this and how they liked it.
Old May 10, 2007 | 10:23 PM
oneclean97z's Avatar
just be careful of where exactlyit is cause of the gases coming out and getting on while running. ive heard of side exits exhaust ruining body panels
Old May 11, 2007 | 01:58 AM
Greg Norris's Avatar
its going to be loud regardless of where you mount it, but keep in mind its a lot easier on the ears to have it dump at the axle. mine is manual at the cat, well, really in place of the cat. and its jammed open from the heat, its loud, and it almost gets annoying after a while...almost.
Old May 11, 2007 | 08:02 AM
teke184's Avatar
you'll lose ground clearance. the cutout and the motor are bulky.
there is an indentation just before the axle, fits a cutout and e-plate perfectly.
and really...does 2ft of straight 3" pipe have any affect on power? NO
but it will help sound inside the car
Old May 11, 2007 | 10:42 AM
hey01's Avatar
well im getting an electric so i can keep it closed under normal driving and open it when I want the extra power.
so teke184 your saying placement doesn't effect power? wouldn't the closwer you get to the header be the best cause the gasses are the hottest, therfore would have a greater effect on HP.
Old May 11, 2007 | 10:58 AM
teke184's Avatar
you're talking a distance difference of about 2ft....so the power difference between right off the ypipe and jus tbefore the axle will be a fraction of a hp at best.
probably going real crazy and putting dual cutouts right after headers only gains you a couple hp over a single cutout on most moderate hp level cars.
i'm sure on a 500hp engine it would be more, but for bolt ons...no way.
PopoFormula
Oct 12, 2015 04:19 PM
colts0455
Sep 11, 2015 06:16 PM
colts0455
Jul 20, 2015 09:52 AM
Latronaxe
Jul 17, 2015 11:55 AM
