relay question
Old Apr 5, 2007 | 06:49 PM
jasonisdn's Avatar
relay question
this is for a mallory install with nitrous. can i wire a relay as a ground source only. say it has the 12 volt switch source and the other 3 are gounds. 1 gound for the relay itself to ground, then the incoming ground signal and the outgoing wire. it will get its 12 volts when i arm the nitrous system. will a relay work like this, in my mind it would but i am not an electrician.
Old Apr 5, 2007 | 09:51 PM
Boosted_Z28's Avatar
Yes, a relay can be used to provide a ground to a device. Just ensure that the ground source is a good solid connection and whenever possible use the negative battery terminal itself as the source.
Old Apr 5, 2007 | 10:48 PM
jasonisdn's Avatar
thank you boosted , just wanted to confirm i wasn't on the wrong track.
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Scottyboy
Feb 11, 2015 10:28 PM
Jeff1904
Jan 3, 2015 12:00 AM
kandied91z
Aug 6, 2002 02:01 PM
kandied91z
Aug 6, 2002 01:18 AM
