Peptobismal looking fluid?
Old Apr 1, 2007 | 02:04 PM
Wildwill2855's Avatar
i was driving and seen smoke, i knew it was fluid out of my a4 from the fluid lines, so i pull over and it was pink like pepto. So i know im going to need a rebuild im sure. Is that from the cooler inside of the radiator leaking and mixing? But my coolant is green and this was pretty pink. Also i just tossed in a new vig 3200, will that be reusable? what does this sound like to you trans experts thanks.
Old Apr 1, 2007 | 03:49 PM
12SCNDZ's Avatar
Sounds like water/coolant in the fluid. It's most likely because of a bad cooler in the radiator. As odd as it seems, you don't usually get trans fluid in the coolant.
Anytime a transmission gets water in it, it should be gone through. The water/coolant will break down the glue that holds the clutch material to the steel plates.
Sounds like you'll need a new radiator, too.
There's no real good way to get all the water/coolant out of the converter.
Frank
CPT
93 RedBird
Nov 15, 2015 08:24 AM
blac94Z
Nov 4, 2015 01:59 PM
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
